Notched Joists
26 Feb 2018
I have a 50’s ex-council house, I’ve noticed that there are quite a few holes & notches cut in the joists
The house has been rewired twice and also had storage heaters fitted & removed, it also has an old gas pipe notched in-to the joists
It had Gas central heating fitted prior to my purchase (think this was fitted in 2002)
I have noticed that the main piping for the heating runs across the upstairs floor with two notches cut right though the centre of the joists
None of the notches or holes I have seen meet the rules laid down in the current building regs, was this common practice or have the regs changed?
It's always been common practice.
Houses don't fall down due to it, just the floor gets more bouncy/noisy a the finishes below can crack and other minor issues.
Our big bedroom had the issue, so I glued and screwed some plywood and added herring bone struts. Helped a lot. If you didn't notice any issue then don't worry.
Same here seemed common practice, I checked out the latest regs on notched joists and as I presumed every one of my upstairs back bedroom floor joists has a massive chunk notched out in possibly the worst place it could be (bottom centre). The house is still standing so I'm not worried at all about it.
