- Joined
- 15 Jan 2007
- Messages
- 4
- Reaction score
- 0
- Country
hey all, writing from america here.
i have been doing a bit of electrical work around the home and today installed a dimmer switch. it isnt working quite properly though and im afraid ill burn the building down.
I am using a ceiling lamp with 4 small Halogen bulbs (G4 12V 20W).
The dimmer isn't grounded because I am in an old building and have nothing to ground it to. Hope this isn't a major issue.
So I installed the dimmer and the fixture works, but it reacts oddly to adjustments in the wheel. At full power it works great (though is moderately dimmer than when I was just using a switch). When I turn the know down it will turn off, then as I continue to turn it it will go back one at a lower brightness. The lower 2/3 of the wheel settings always leaves the lights off. What concerns me most is the dimmer buzzes when set to certain locations.
Could someone suggest what might be the issue? It could be the lamp, or maybe the old wiring, or lack of ground, or the wires on the dimmer are backwards? Too many options and I am pretty clueless.
Thanks!!!
____________________________________
Lynda, moderator
moved to electrics outside the UK
Please also note 6 & 7 here
Thanks!!!
Lynda, moderator
