Any suggestions greatfully received.
A friend has just asked me to sort out why their RCD keeps tripping.
It generally trips in the hight or early morning, although it did trip once when they turned a computer on. Apart from the once with the PC, the only loads running are fridge, freezer and heating. The house is approx 17 years old, PME supply and 80A FCD as main switch, first time I,ve seen a RCD with a small lever as the test switch instead of a button.
When I went tonight, we turned everything on, opened the fridge & freezer doors to get the pumps cycling and flicked the heating on & off to get that switching and nothing tripped.
They also stated that the supply is on and off fairly regularly with them waking up to flashing clocks etc.
Is there anything you can suggest for me to check?
