Oak Floor - have I got it right?
4 Jan 2006
Essex
I've ordered a 21mm x 160mm solid oak, t&g floor with a brushed and oiled finish which I am going to lay myself and would like confirmation that I am going about it the right way.
I'm laying it in my lounge (5.6x5.2m) which has a 65mm screed on a DPM over a beam and block (suspended) floor. The house is 15 years old so presumably the screed is dry!
I intend to lay the boards floating using Elastilon underlay and, if anyone advises it, I am open to the suggestion of a polythene DPM and/or a foam type underlay under the Elastilon.
I will allow the boards to acclimatise for at least 7 days and at this time of year are they likely to have a high or low moisture content? Would it be a good idea to try to stretch the Elastilon (as mentioned on their website)so that the boarding is under tension right from the start?
Has anyone got any comments or suggestions?
Elastilon doesn't come with an integrated DPM, so you should use a separate DPM layer first.
If the wood has a normal moist content when it arrives at your home (between the allowed 8 - 12%) after 7 days it will have adjusted to the humidity of your house i.e. is your home climate has a high humidity your wood will absorb that and vice versa. But 9 times out of 10 in this season (heating season, dry air outside) the humidity will be low.
Follow their instructions, they - Dutch ;-) - have invented the stuff and know best ;-)
