Got a problem with alpha ocean 240e.The hot water flowrate is fine but the temperature is only luke warm.If you close the tap to a trickle the it gets hot. The problem has happened before and an engineer descaled the heat exchanger and it worked fine for about a year. The heating side is fine. Just wondering if the heat exchanger needs changing or if anything else needs checking. I have"nt got a service manual. Can anyone help.
