I have an odd leak from my bathroom ceiling (well its my partners) which first happened 4 weeks ago and then last night. Prior to both of these occasions my partner had the hot water on for several hours (overnight) rather than the usual 1-2 hours.
Just before the first time my partner's hot water tank broke down due to an electrical burn out (not technical) of the wires. An electrician fixed the problem however the first leak was later that night. Initially I thought it may be the roof leaking (it is an attic flat) however the problem does not seem to to directly correlate with rainfall. The first occasion there had been rain however it has not leaked in the last 4 weeks despite major downpours.
The water tank rests almost directly overhead - and the leak is ride on the edge. I wondered if this could also be where the pipes are too. In addition we were not staying at the property much in the last 4 weeks and have only really been around for the last week. So I am thinking the leak is associated with pipes/tank as this is only used when we are present and not weather.
The leakage of water is approximately 10-15ml per occasion and is brown in colour (rusty or the wood varnish from the ceiling?). The leak runs the length of approximately 75cm in a line along one wooden slat. Thankfully this is over the bath!
Has anyone any ideas of what this could be and whether to call a plumber or a roofer (it is a flat roof above this section) in?
