Had a conservatory built last year and installed 2x double sockets on 2 4mm2 cables as radial spurs off 2 sockets in the living room ring. The cables are run in the cavity, (3" brick outer, 3" thermal block inner with a 3" cavity and cables laying on a strip of dpc on the concrete. 1 light fitting and switch taken from the living room light, (loop-in system). Is this ok? Also no-one from building works or LAB notified. Am I in trouble?
Everything tested and up to 16th regs BTW.
