Oil-based undercoat going off very fast
22 Jan 2012
Jersey
I've just painted 2 new window boards with a coat of Crown Trade Full Undercoat.
The tin is a year old and was pretty thick, so I mixed in some white spirit to thin it down a bit.
I painted the boards, and within 20 minutes it was touch dry! This seems way too quick to me. I didn't do very thin coats, thick enough to cover the pencil marks on the primered surface.
Should I be concerned? I don't like painting at all, so really don't want to have to apply extra layers if its gone off quickly and patchy.
22 Jan 2012
Jersey
Yeah but this seems way too fast, the room is about 16degrees. I did another window this morning and the start was dry by the time I got to the end (And I'm not that slow!)
Wondering if I need a new tin....
28 Oct 2005
Undercoat is very porous hence the solvent dries quicker. that is a GOOD thing.
22 Jan 2012
Jersey
I bought a new tin of the same paint Friday, and did a coat of that. It still dried much faster than the instructions suggest, but it did take about an hour, so I was able to work to a wet edge.
Suspect storing the old tin in the loft over the last year has knackered it.
16 Jun 2006
London
If you want a longer working window, add Owatrol rather than WS. Use WS as a thinner if the paint is too thick.
If you want to increase the actual curing time, add Terebine. It wont have much effect on the wet edge but will allow between coat sanding earlier and speed up touch dry times.
I normally use all three simultaneously.
