I hope I am accurately describing this post. I have an ages old boiler 'Delheat' don't think they are in business still. The burner is a Selectros and at some time the motor has been changed to a EOGB tipo 60.2.90M and it looks like the con-box has been changed to a Satronic TF701. About 2 weeks ago the boiler wouldn't start because the motor wouldn't spin, I traced this to a faulty capacitor and replaced it with one from Maplins that was 3 microfarad rather than original 4. The boiler worked OK for about a week then would fire up but not stay on, though this was an intermittent fault. I replaced the 3 microfarad cap with an 8 mf one (all are motor starting rated at 440V though they have 4 terminals rather than 2 so I just used 2 terminal and insulated the spares.).
This solved the problem though when then boiler was warming up from cold it would run for quite a few mins (the radiators got to working temp) then switch off and then switch on again almost immediately, the fan would start, the oil would flow, flames would happen then after about 10 secs the control box would lock out. This could be reset after about 30 mins and the boiler would run normally until the CH was satisfied, then when and if the CH operated the boiler by calling for heat, then it would work properly all day, being controlled by the CH. I noticed quite a lot of soot built up, so much so that it continued to burn after the burner locked out; I gave it a good clean, photocell is clean as far as I can see.
Today the boiler has ignited but then locked out after 10 secs as above and I can't clear the fault. I have looped out the thermal cut out and the thermostat to test that part of the system and the same still happens.
I'm not being tight I know the boiler is basically past it but I'm extending the house in the summer and want to wait until then before replacing the system as I shall be moving the boiler location.
Oh and I've tried to get about 3 engineers round to look at it but no-one's interested.
