my hot water is working but I cannot get the heating to work , it is a 20/25 heatslave combi boiler
Agile said:...................
If you convince yourself its correctly set then its just possible the boiler diverter valve is failed but that is VERY unusal to give DHW and not HW !
You may need to call a boiler expert if it really has failed.
Tony
wilhelm said:see if little lever on divertor valve moves when ch selected.....turn down dhw stat on boiler. it might fust be synchon motor in valve. awkward on a honeywell and a tw £t on a drayton za valve.......which you may have.
