Yes I know installing an oil appliance on the second floor is not the best place but does fall within the regs! It is taking the place of an airing cupboard and cylinder Y plan set-up.
The suction head would be about 2.5 -3 meters. Was going to add a Tiger Loop to aid de-aeration but can a boiler pump raise this height without bad wear and tear? An oil lifter would add quite a bit to the over all price in time and labour. What does a 10mm check valve look like as I assume it would also need this in the oil line?
OILMAN...where are you!
