- Joined
- 27 Mar 2005
- Messages
- 70
- Reaction score
- 2
- Country
I plan to replace my existing metal oil tank (currently raised on brick pillars) with a plastic tank. I would like to situate the new tank further away from house than the current tank, and situate it at ground level rather than raised on pillars. I am familiar with the regs regarding situating the tank.
The new location will be approx. at the same level as the boiler (if not slightly higher) , about 25 metres away from the boiler.
To combat the fact that I am lowering the tank, I propose fitting a GOK GS2000 de-aeration device, which I undertsand does not vent the gases so can be fitting internally in the boiler cupboard in the kitchen.
My boiler is a Danesmoor 15/19 with an Electro Oil Inter B9 burner.
Questions:
1. Is my burner a "presssure jet burner", hence compatible with the single pipe lift system with de-aerator?
2. Does the above proposal sound like it will work?
3. Any special things to know about fitting the de-aerator, e.g. height in the boiler cupboard relative to the boiler or oil tank, regulations regarding proximity to the boiler, etc?
Jonathan
Questions:
Jonathan
