Hi all,
I have a Worcester greenstar heatslave 18/25 oil combi boiler that’s three years old, serviced last year. First problem is that recently I have noticed the radiators are sometimes getting very hot, way too hot to touch and hotter than usual, thermostats all ok and I can’t see any reason for this.
Secondly I had a mixer shower installed recently. This runs fine with the boilers small hot water store, but once this runs out after a few minutes and water is heated directly off the mains it goes luke warm. I measured it at 35 degrees at the shower and other hot taps. I turned the inlet valve on the boiler down to almost shut to restrict the water flow, but it made no difference. I know a combi will struggle with cold mains at this time of year but this is a high flow rate boiler of 18 litres per minute, any ideas what might be wrong?
It was a complete new system 3 years ago, properly flushed and sentinel inhibitor added, never lost any pressure!
Graham.
Graham.
