- Joined
- 10 Jul 2004
- Messages
- 15,974
- Reaction score
- 6,504
- Country
Useless piece of ****e, CH works fine, diverter was leaking so changed that anyway, fitted new CH sensor and DHW sensor, Litres a min flow rate correct, gas rate correct, gets decent temp rise but then cuts off without modulating down, if you turn the DHW stat down and up it modulates to suit, so gas valve working ok, connect a "loose" CH sensor to the red wires and it works fine, reconnect to "fitted" sensor and it works a while then cuts off with no modulation and water runs cool then boiler cuts in and out in and out so on on on on.
There is no plated xchanger on these boilers.
