Have an old loft conversion done about 1976 with dorma - not quite the full 9m width of the property.
I have the original plans, it was done by a builder who owned the property and carried out extensive alterations.
I was updating a room below the loft, and investigating the dipping ceiling of the room (not massively dopped - 2") the problem is with the origional loft conversion. There are 3 long 8x2 joists which have been sistered ---====--- to make the width of the property sitting on the roof ties, with a timber supporting wall in the middle of the property.
Annoyingly the joist above the room which has dipped doesn't actually go into the external brick wall for support, it just touches it - the weight is on the roof ties / ceiling - hence the dip. This area of the loft has some, now bypassed, water tanks. The other side sits on a chimney breast.
Acro props have been used to take the ceiling bow out, I'm told only as a short term fix another joist could be put in the loft and provide support.
I understand that this is a structural issue and needs a structural engineer. I just wanted to know would getting steels in mean taking the whole loft conversion apart and essentially it being done again to current regs?
