    Dismiss Notice
Old clay drains blocked
Discussion in 'Building' started by LEGH, 18 Apr 2021.
  1. LEGH
    LEGH
    18 Apr 2021
    Thanks Received:
    Country:
    Hi, I live in a 1930's semi. Underneath our patio, there is a run of clay pipes which seem to be for run off water. They come across a neighbouring property but then I don't know where they run to as they can't be seen on the other neighbours property - get house us set further back. I don't imagine the pipes going under her house? Anyway...the clay pipes are blocked with silt etc. My patio floods when it rains hard. Does anyone know if the pipes are my responsibility or the water board? I've seen some info about ore-1937 houses but can't get to grips with it. I thought about lifting one of the loose pipes & jet washing but am afraid if might just block altogether further along. Can anyone advise? Thanks
  2. JohnD
    JohnD
    15 Nov 2005
    73,458
    Thanks Received:
    4,230
    Crossgates, Europe
    Country:
    Cook Islands
    old clay drains are usually cracked, broken and leaking, mud may have got into yours.
    Please post photos of what you can see, and any manhole covers, and a plan drawing of what you think the route is. You can "copy and paste" from the files on your phone or camera into your reply.
    look especially for patches of cracked, repaired or sunken paving, concrete or ground, which are typical around drain leaks.
    try running a sik or bath and see if any water goes through them. And tip buckets of water down the gullies that your gutter downpipes go to.
    Actual land drains are fairly uncommon.
  3. Sponsored Links
  4. CBW
    CBW
    26 Sep 2019
    8,404
    Thanks Received:
    2,200
    North
    Country:
    If the drains are shared, generally water boards responsibility.
    • Thanks Thanks x 1
  5. freddiemercurystwin
    freddiemercurystwin
    21 Jan 2007
    19,747
    Thanks Received:
    2,206
    Devon
    Country:
  6. DIYnot Local
    3 Sep 2019
    Country:
  7. Sponsored Links
Loading...
Share This Page
