Hi All,
I have just moved into a house in suburban Leeds that is about 100 years old. Although the house has been re-wired in the last 20 years, it's not been a good job. I am weighing up the work that needs doing. My first concern is the earthing. It appears that the only earthing is a 6mm wire going to incoming the cold water pipe. there are two other earth wires to the CU, both disconnected. The supply to the house is obviously very old, it comes in underground on two core armoured cable that is bitumen wrapped. There is no earth provided. I contacted YEDL about the earth and they said they could come and check it and install an earth if necessary. This may be free or cost £30 + VAT. My question is, will they just expose the armour and put a strap or similar round it for the earth, or will they convert it to TNC-S, or provide an earthing rod? I have heard that there can be problems with TNC-S earthing and tripping RCCDs.
I am also concerned about the main fuses - I understand that having a fused neutral is bad practice, and they are only rathed at 60A, which might be a litte low for a large house. I assume that YEDL would say that this needed changing, who would be responsible for paying for this work?
Any comments appreciated
