The current system fitted is very early simple gravity system type with only a pump in the central heating circuit, with no stats or programmer fitted.... The system is piped to a 4 pipe Trianco oil boiler.
Basically, what I want to do is fit a Programmer and Room Stat to the system without going to the bother of fitting the 28mm two port valve and tank stat..
My question is..Will it work safely? If yes! Will it work reasonably efficiently in comparison to the one currently fitted? All I want to do is control the CH circuit!
In essence, when completed, it would look a bit like a Honeywell, Sundial C Plan minus the 28mm valve and tank stat!
Alan
Alan
