Old towel rail - how to attach to c/h?
21 Feb 2005
Got one of those 1950s chrome towel rails with an iron radiator in the middle. It's still got the original pipe connectors screwed in, and I can't find anything that will let me connect them to 15mm pipe. And I can't get the connectors out.
The open end of the connector is like a union connector or the fittings you get to attach a radiator to a valve - a large nut and a flange. The nut's internal diameter is 1 1/4 inch, and the internal diameter of the flange is 3/4 inch. Is there anything that will hook up to this wierd nut and allow me to fit a normal fitting? It's a problem because I can't put the bathroom floor down until this towel rail is in.
Cheers
Dan
Had same problem this week with an old towel rail very unusual thread on it and could not get anything to fit . Lucky enough customer worked in steel fabricators and took it into work and got it tapped out to take a 3/4 fitting. Also came across something i had never seen before the copper pipe in house was that thick all joints where cut and threaded with no solder joints at all.
post a pic and I'll tell you what to do, and what to get, and where to get it.
:roll: :roll:
images
:wink:
