It is important to remember that any new electrical works msut comply with the current regulations. Usually this means an RCD/RCDs will be required for new circuits or circuits that are being altered.
If I read your posts correcly this means that you'll need RCD protection for:
The towel rail
Bathroom lighting
Circuits that wil be added to as a result of your bathroom/bedroom re-arrangements.
IMO, together with the age/condition of your existing board, that all adds up to a new consumer unit.
Hi - the installation of a new consumer unit will cost too much and in my unprofessional opinion (so not worth much!) not necessary.
Existing Bathroom
Will become a bedroom, has a lighting pendant (doesn't meet any sort of regs!) in it so I will just be changing the fitting and replacing the switch. I will need to add some plug sockets in their but can extend the existing ring (only 4 plug sockets upstairs at the moment so will bring this upto 6).
Existing bedroom
Newly created smaller bedroom (from the split) will utilise the original lighting & switch feed, just need to move them.
Newly created bathroom will have new elec rad, shower fan & light and mains downlighters. This will all feed from the spare slot on CU as decided above.
My understanding on part P
I can add to existing lighting and plug socket rings without an RCD (they are not wet areas) and it is non notifiable works.
Loop in setups
Ground floor lighting - with new kitchen extension, 4 additional spots will be added on existing lighting ring - total new wattage = 1150W (5A)
1st floor lighting - no addition to existing wattage = 580W (2.5A)
With regards to the multi radial outlets I have no limitations on number of sockets and will be adding extra sockets to elliminate the use of extension leads. There will be no change in the overall draw.
Comments welcomed on my plans. Is the total wattage for the ground floor lighting cutting it too close to the bone?
