Hello there,
I was recently trying to change a gate valve that keeps letting cold water through, even though it has been shut off (suspect mechanism has corroded after 20 years or so). Now i happen to have a rather annoying problem, whereby on either side of the gate valve, the two olives are jammed on to the valve's threads and so i can't pull it out. I've tried twisting the gate valve but that does nothing and i'm worried i might make the situation worse.
I've read about those olive removal tools, but not sure if they'd apply in my situation? Is there anything else i can try before resorting to buy one? I was thinking of fixing the gate valve back up and cutting the pipe slightly higher up and attaching a working ball valve there - although it would look messy. Is that not a good idea?
Thanks in advance for any help you may be able to provide
P.S. Please see the picture below for a better idea. Oh and pipe is 22mm.
