If you lads remember, in one of my previous posts I suggested that the previous homeowner in my house might have done a lot of the wiring himself because of the strange things I was encountering whilst checking around ?
Well, I think I have just confirmed that. I had a little problem with the heating a couple of days ago & the one thing I found that looked weird was the way the circulating pump was partially shuttered off, so I decided to remove it to check that I could get access to the wiring because I want to eventually feed the CH off it's own feed from the CU. This is what I found :-
This can't wait for the LABC to come round so I'm going to get this sorted, or at least make it safe until they do. I've seen it done in the past where a surface pattress is fitted with a choc-block & the wires terminated within, is this still OK ?
It's prolly gonna be the way I do it anyway for now but it would be nice if it's within the regs, then at least I can do it permanently.
Cheers
Cheers
