In view of what has been written in the other threads, do we now conclude that omission of overload protection for ovens should not be done?
If so, for what sort of appliances was 433 intended?
I obviously cannot argue with SUNRAY's experiences but that a fault as described caused a 13A fuse to blow does not mean that the faulty appliance would have sustained, for example, four times its design current 'for ever' or until the (undersized for OPD) flex melted.
I still do not see how an oven element filament can fault to earth somewhere along its length and bolt itself satisfactorily to the casing as if it were the manufacturers joint at the end. Surely the first incidental very small CSA contact would arc and blow itself away.
Is there a specific reason?
Such is definitely not the case in things like ovens, immersion heaters and showers, even if a 1kW oven element might be twice as long (coiled) as a 2kW one - if it is.
That does seem to be a very odd way of doing things. Why would you not want a 12" 1kW one? Why would you want a six feet long one?That particular heating element is from a manufacturers standard range of: 12" 6KW, 14.5" 5KW, 18" 4KW, 24" 3KW, 29" 2.5KW, 36" 2KW, 48" 1.5KW, 72" 1KW. (Rated at 240V) Notice any pattern emerging? Yes indeed they are all made using different lengths of the same product.
