one for the SE's and anyone else that can answer (sorry)
13 Feb 2007
Warwickshire
Hi
Is it usual for blockwork to be build up directly off floor boards at first floor and if so why would they do this?
It used to be common practice. Iv'e done it with lightweight 3 inch blocks off sole plates at late as the 70's.
Not an SE but an MIMechE but what the ****
Owned a house where this had been done on chipboard. Bfore wwe bought it they had installed heating and the plumber cut a piece of floor out along the wall leaving the wall sitting on chipboard cantilevered out about 12" from and parallel to the next joist - it dropped 3/4".
Took the wall down and replaced it with a stud.
It may be common but is a short cut, I believe the block wall should be stood on 2 lenths of 3x2.
I was wondering if it was in some way supporting the roof structure but couldn't see why they would build like this as some walls are stud?
It's not common these days but certainly was in the past. Most likely it was to do with sound insulation more than anything else. I once got caught out by third floor walls in a 180 yr old building that were off floorboards with nothing below. I assumed they were stud walls but they turned out to be brick.
