- Joined
- 19 Jan 2004
- Messages
- 74
- Reaction score
- 0
- Country
I have a one pipe system on a Ideal Mexico2 boiler. Works well and is serviced by BG as prior owners did so seemed good to continue.
I need to add rads x 2 as there are areas that require greater output.
I can work under suspended timber/block floor and need to knock through block work to install.
Can I 'T' off to a radiator I add with a run of approx 1 meter from the 22mm using 15mm pipe?
Or do I have to run the 22 mm pipe nearer the new rads? I am assuming flow will be impaired on 15mm pipe on this system?
Any help much appreciated!
