Hi Everyone,
We recently had new radiators installed whilst having our house gutted. The builders said they had serviced the boiler.
We blocked up our through lounge leaving a huge double bay radiator in a small room so was expecting to turn it to low once the cold weather started.
Anyway its only warm, on the right hand side the pipe leading up is roasting hot. On the other side there is a TRV which as I said is on the highest setting. I have bled the radiator but it was fine.
Should I try and turn the lockshield a little on the left to see if it makes a difference. Im just a bit scared so thought I'd check with you guys first.
Any other advice would be greatly appreciated
