Only 4 out of 8 radiators working
The pipe to the hot water was warm and yeah sometimes the hot water does run really hot
First suspicion then would be the 3 way valve. If its not shutting off to the HW port fully, then the CH system will be robbed of water. Turning off the Hot Rads may not achieve much as if the resistance for the flow to get through the CH circuit is greater than the HW cylinder then the water will take the easier path. Is there a valve on the pipe leaving the bottom of the cylinder, underneath where the connection from the 3 port valve enters?
I did think it could be blocked but there’s water going to the rad just cold
Just read a lot of bad things about slim plastic pipes being used and ease of blockage.
