I have a Potterton Performa system boiler. It will only heat-up the water in the cylinder when the heating is on. This means that, if I need more hot water, I have to turn the thermostat up. Shouldn't the boiler heat-up the water, even when the heating is not on?
As already said it will probably be a faulty zone valve, if the water is heating up when the heating is on then the hot water valve will be open but the microswitch isint making, chances are you can just change the valve head (depending on make/model)
