Hoping someone can advise regarding problems I'm having with a Garador PN31 manual up-&-over door ...
Today, when I tried to go in, the door 'jammed' just as I got it above head height. After various bits of messing about (including getting SWMBO to raise/lower it while I was inside trying to see what was wrong - you can imaging I'm popular about that ! ), it looks like the (from the inside) right-hand side cable mechanism is failing to retract down when it gets almost open - the cable instead 'pushes' out to the side/top.
The side mechanism has a cover on it - I've tried to remove it but it won't budge (I guess there is more than just the top & bottom screw I saw), as I'm guessing there is something there jamming on lowering down ?
Advice is welcome on how I can resolve this problem !
Mike
Mike
