- Joined
- 5 Nov 2008
- Messages
- 194
- Reaction score
- 3
- Country
The house is late Victorian. As can be seen by the size of the spirit level in the photo, the original fireplace opening is about 4 ft high and would originally have had a cooking range in it. Over the years there have been several different fires and the fireplace has been modified several times, each fire blocking up a bit more of the original opening.
I want to open the fireplace up to the original size, roughly where the yellow lines are. There is a substantial amount of brickwork that appears non original or non-structural but before I start hacking, I wonder if anybody has experience of such things. I am getting a professional in to give a quote, but that is in two weeks and I want to do as much as I can beforehand (albeit safely and without wrecking the house!)
It seems as if the original open fireplace has been adapted by building a sort of ‘venturi’ as shown roughly by the red lines. On the righthand side there is very rough brickwork supporting it but on the left it is unsupported (hence the wooden chocks - what few bricks were under it were loose). I am guessing that the majority of brickwork on the left was removed to make space for the back boiler. None of the bricks match the rest of the house and the job is very poorly done. I am assuming that these and the ‘venturi’ were a later addition, are not structural and hence can be removed. Has anybody found similar modifications in the past, and can they be removed safely?
Before anyone says it, assuming the opening can be restored, I will be putting a new lintel in under the original brick ‘arch’!
TIA
Mike
TIA
Mike
