Opinion on bay window vertical retile
15 Nov 2026
I'm looking for a second opinion. Any help would be greatly appreciated.
I had a builder retile my bay window. He decided to leave a near full tile at the bottom with mimimum headlap which has left the bottom tiles loose (I can move some with my little finger) and lath exposed through the gaps. He has also joined the corner tiles with sealant.
These are the major things I'm unhappy with though there's more.
This is also his second attempt. First attempt left wonky tiles, big gaps between tiles and corner tiles very loose. I feel like he hasn't done one of these before!
What are your thoughts?
Many thanks.
Jim
Many thanks.
Jim
Where are the LH and RH corner tiles? :oops:
It's rubbish. Hopefully you didn't pay very much for it. If you can see the woodwork through the tiles then the rain can go the same way. There should be a tile under every joint.
The corners need corner tiles. I've seen lots done by mitring plain tiles in recent years but it isn't adequate. There are tiles made specially for this, in various different angles to suit whatever yours happens to be. Of course they cost many times more than a plain tile plus a squirt of silicone, and they're not available in all makes and models.
Start by measuring the angle, find a tile that is available in this angle, get the rest to match. If in doubt contact a decent roofing supplier. Buy them yourself to avoid doubt. Then get someone to fit them. Or just hire a scaffold tower and DIY it.
Example tile...
The price is the reason why many are using silicone. Most seem to think it's OK, perhaps it is IF there's a strong waterproof liner behind the tiles. But I doubt this is usually the case.
Here's a feller proudly doing the sort of job you have...
Clearly opinions differ!
I just looked at your photos again, looks like yours is 90 degrees. In which case getting corner tiles should be easy and not silly expensive. Ignore my link to the 135 degree ones.
Thank you for taking the time to reply.
I haven't paid him a penny. He threatened legal action and I told him I'd counter claim under the Consumer Rights Act 2015. He backed down.
My main concern is water getting in. I'm just sick of dealing with building work! This geezer had almost impeccable reviews going back 12 years!
Any advice on finding the right builder for the job? I'm in Newcastle upon Tyne.
No idea. But sadly how he's done it is probably considered acceptable to many these days, including that youtuber I linked above.
You should have agreed on how it would be done at the outset, not after.
I had a similar situation with a contractor once. I told him to clear off and sue if not happy. He did. It cost me a day off work, loads of prep time and resulted in me paying him half. I'd have been better off just paying the bill and letting him win.
Get someone else in, get a quote to remedy it. Chances are they can re-use the battens and tiles anyway, so you should be paying the bloke who did this something.
