Hi All,
I need to replace the back door in our bungalow; we're losing an old leaky/tatty lean-to which will expose the back door to the elements. Although the existing back door is UPVC, it's very old and tired and needs replacing.
The back door obviously didn't exist in the original build of our bungalow as the hole for it has been saw-cut. And it's been cut badly! The cuts aren't perfectly straight and you can see in a few places where the cut has gone off level and been corrected. It looks really naff!
I guess the ideal way to solve this would be to get a builder in to come and remove the bricks and tooth it in properly - but ultimately we plan to build a utility room on the back and hence this will eventually be over plastered anyway so won't be on show.
In the short term - I have a second hand door - what options do I have to tidy up the brickwork? Are there any cloaking profiles etc designed for this?
Leccy.
Leccy.
