I consider myself to be a fairly experienced DIYer and am currently redocarating my my house which is 3 years old.
I am now on my fourth room which is my daughters bedroom, I am a perfectionist when it comes to decorating which annoys my mrs no end, so i am looking for some advise on how to speed up the process a little.
At the moment it takes me around two weeks to prep and paint to my high standard and was thinking that maybe i am doing things wrong in terms of the order in which i work.
1. Rake out old caulk from skirting boards and architraves, which have now shrunk due to moisture content when fitted, Around 5-6 hours work.
2. Rub down all wood work and remove paint from knotts. Around 3 hours work.
3. Zinsser BIN all knotts and bare wood, 2 coates. Around 2 hours work.
4. Re caulk all joints in skirting/architraves. Around 1 hour.
5. 1 coat of undercoat on all woodwork. Around 4 hours work.
6. 2 coates of teflon imulsion on walls. Around 6 hours work.
7. light rubdown with wet sandpaper (400 grade) all woodwork to a glass smooth finnish. Around 2 hours work.
8. Mask off around carpets, vacuum woodwork and wipe down with tack cloth. Around 1 hour.
9. 1 coat of satin wood all woodwork. Around 5 hours work.
when dry remove dust sheets, vacuum room and replace furniture.
As you can see from above its a long process. Am i being a bit too fussy?
Any suggestions to speed the process up?
