I have two rooms that are stripped back to the floor joists,
ceiling joists, brick wall, and partition between the rooms
removed.
Each room has one outside wall and one party wall. The partition
ran perpendicular to the outside wall. The party walls were opposite the partition.
Whats the best order to rebuild in? I'm thinking:
1. Fit insulation between ceiling joists
2. Put up end, sole, and top 2x4's for partition
3. Batten walls and ceiling (were required)
4. 1st fix electrics
5. Add other sound/thermal insulation as required
6. Fit new sub-floor (and do pipes for radiators)
7. plasterboard outside walls (so I can run a continuous
piece of board over the partition end plate)
8. Plasterboard party walls
9. Plasterboard ceiling
10. Plasterboard partition and remaining internal wall
11. plaster skip coat
12. 2nd fix electrics
13. Fit skirting board and door trim
14. Redecorate
15. Fit radiators
16. Fit floor covering
Ian
removed.
14. Redecorate
15. Fit radiators
Ian
