That's the problem. I have the rectangular sts fixing brackets and adhesive.
Marmox use the circular washers and scrim tape.
While sts brackets will probably be fine, unsure about the glue instead of scrim tap. Wickes dont even sell the marmox fixings so its ballsed up my plans.
I called them, they said they'd get back to me today. Obviously they haven't
If it's the Mega Adhesive then it's really strong stuff. Use the adhesive along every joint too, just let it foam up and after about 15mins use a sharp scraper or chisel to cut the excess off the surface. The rectangular washers will be fine also.
