orsa c
20 Dec 2011
Glasgow
hi there just wanting to find out had to get second hand dials gauge fitted coz my other ones were faulty now that other dial have been fitted the car spanner icon on dashboard keeps flashing continuesly car will start for seconds then die out help needed thank you
You were given the correct advice weeks ago but chose to ignore it
They require programming to the car using suitable diagnostic equipment
thank you for reply but the thing is the garage said they it?but a have been told just get full ECU BCU SET as they are all from same car and would work fine?
Yes, but I think you might have to use the key from the donor car. It sounds as though the dash/immobilizer doesn't recognize the key.
Happy Christmas, hope this helps
yes am getting the key from the donar car with ecu,bcu,clocks,transpoter,so will no need to reprogram cause its coming from the one car? MERRY CHRISTMAS ALL BEST FOR 2013
