Outdoor Electrics - water ingress
30 Mar 2008
Cambridgeshire
Hi, about 3 years ago I put an outside 4 way weatherproof switch on a wall. I wired in a pond pump, ultraviolet light and 2 spare. All had been working well until I went to switch it back on today after its winter off. It tripped the rcd that it is attached to inside the house. I have now discovered that some water has gotten into the switch and pooled by the earth wires clamp. It has obviously been there a while as it has turned a nice wet rusty colour. I have tried to dry it and get it going but it still trips out the rcd. Is my pump now broken? Will I need to replace the switches or will it work once it has dried?
Any help is appreciated as a new pump will be £300!
how can your pump be broken? it sits in water 24 /7
a multi meter will be of no use since it can not read at the right voltage to detect a L-E or N-E short
your box has either leaked or its condensation.
I would get a new one and drill small holes in the down side facing side
filters should be left on 24/7 even through winter, more info is here
looks like you need a new switch.
In future drill a drain hole in the bottom of the box. No seal is perfect and you really don't want to create the situation where once water gets in it never gets out.
i guess plugwash is just agreeing with me then :)
thats 2 people that said drill holes, and 2 people that said leave filter on 24 / 7
I don't think I agree with this:
I find lots of RCD tripping faults due to faulty pumps.
Or did I misinterpret what you said?
you missinterpreted what i said.
good pumps just give up the ghost. i have only ever had one trip an rcd, even then it wasnt the pump itself but the float swicth on the pump, still it served its life, i sliced it open
Thanks for your advice everyone. I am going to try and replace the switch before I replace the pump, and I will be drilling a hole this time. The pump is an OASE Aquamax, purchased 5 years and 1 month ago, it had a 5 year garauntee! Typical.
