Outside hose fitting
23 Mar 2021
I've bought an outside hose kit, it's exactly what it said it would be ( not suitable for pressure washers) I imagine this is due to the self cutting tap that has the same pressure as my late 40s bladder, I've bought a 15 mm Tee compression to replace it, however I can't find a 3/4 male ( washing machine type hose connector) to a female 15mm connector to join the tee to the washing machine hose, I'm not up for soldering so it will need to be compression, is there a way round this or does anyone know where you can get these,
I had a look at the top one in the shop and due to the cut off tap the flow only comes through a small hole that isn't much bigger than the self cutting tap that came with the kit do you think this is sufficient for a pressure washer?
Probably not, but pressure washers and outside taps are not normally supplied through a washing machine hose.
