Outside Light Switching
31 Mar 2006
Yorkshire
Does anyone know if it is possible to get a standalone PIR sensor that can be wired as two way switching with another to switch a number of outside lights on from either sides of the house?
A link would be appricated, tried screwfix but the wiring diagrams dont seam to have the correct terminals.
Cheers, Adam
Do you really want it to be two way?
If the lights are allready switched on via the proper switch, walking past the PIR will turn them off.
do you mean one set of lights from two pir switches,
You could wire two normal ones wired in parallel
They need to be supplied from the same fcu really for safe isolation as one will liven up the load side of the other one when it is activated.
Like this eg:
