Outside plug for Granny Charger.
If you have an earth rod, then likely a TT supply, not 100% as I have an earth rod and a TN-C-S supply, but a good pointer.
I have never worked out why EVs don't require a class II supply like most out door equipment, but ours is not to wonder why, and for what ever reason we need an earthed supply which will either has a local earth and far enough away from any other earthing system to be safe, or it has some device to disconnect the earth and lives, if there is a loss of PEN.
It does not really matter if some rule says not over 13 amp or not without loss of PEN protection, we have three options:-
1) Don't get an EV.
2) Pay out for loss of PEN protection.
3) Don't take any notice of the rules.
If not taking any notice of the loss of PEN protection, may as well take no notice of the bundled supply rule, RCD requirement rule, and all the rest, you have asked the question, and I have answered.
To my mine the granny charger is to allow the once in a blue moon charging of an EV, using an existing socket, to fit a socket with the whole idea of charging an EV, is something different, I have three double outside sockets, they are to power my leaf blower in the main, and other class II items, not to power an EV even if placed well for doing that job.
I want to cut the power from the outside EV socket but still be able to have power to my inside socket.
Add a 20A switch. No fuse required or desired, as fuses get hot when in use, and when in use for hours at a time at high load, they can get very hot indeed.
I can’t use a charger like hypervolt because my power is looped supply and I don’t want any digging
Hypervolt and most others can be set to a lower current rating internally, such as 16A.
Thank you, are you saying its not advised to use the granny charger 2 or 3 times a week? I can see where you are coming from, I have noticed the plug warm when charging.... food for thought. Thank you.
Thank you but am I still suppose to notify my DNO if installing a Hypervolt reduced to 16A?
