I would like some advice on how to wire up a new outside waterproof socket which is to be fixed to the outside of my extension wall and then i want to be able to operate it from inside the extension.
Thanks guys
The easiest way is run a cable from a socket as a spur, to a 20A dp switch and then to the outside socket.BUT THIS IS A NOTIFIABLE JOBi;e; you need either to tell your local building control dept and pay them lots of dosh or get a registered electrician in who can do the notice a lot cheaper than you can.
