Outside tap install
5 Oct 2008
Nottingham
I want to install an outside bib tap so I can water my garden. I have seen a tap kit for sale, but also was thinking of buying the parts separately.
I know I need a double check valve fitted on the pipe to the tap to stop backflow.
My query is - I have a power drill (240V DeWalt one) whoich is quite good. But I have never drilled right through a masonry wall before.
Will I need a 1/2" or 3/4" drill bit (the large/long ones) and can I use my original drill or will I need a more powerful one? Thanks for your help.
dont buy the tap kit if its the one with plastic hose etc.drill will be fine better with a pilot hole first.dont drill from inside out you will make a mess of your bricks
Hi
Separately best solution.
Yes check valve .Some bib taps have built in check valve. Also isolation valve to turn off supply.
Dewalt good. Drill bit 16mm+ for 15mm pipe on hammer not too fast.
HTH
Thanks all for your help
Is it best to drill with a pilot, say 8mm-10mm first from outside?
Also, should I wrap the pipe to prevent corrosion??
personally i would sleave a 15mm pipe for an outside tap with some 22mm pipe or overflow pipe least any leaks wont find its way to the cavity.so 3/4 inch drill bit would do.your dewalt should be ok far standard block wall.
ok thanks, i'll sleeve the gap between pipe and wall, and is silicone sealant ok to seal gap between pipe and sleevel at each end?
I'll get a 3/4" bit then, any good / decent brand ones? What sort of cost should I be looking at?
yes silicone is alright.if its a one off job id just get a cheap bit.usually the ones at the sheds arent.
