outside tap water running down pipe
25 Sep 2021
think my problem is with the compression when I fit the pipe to tap.is there any push-in plastic compression adaptor i could use
thanks all
Can you provide a photo, or a better description? I’m not entirely sure what you’re asking.
EbgfvHPWX957wRTOJtOTvzYibBLqjrCIb7VAitqZ8AgYAE01VGXg8FNi1rBceyFA8RFnWsGlkt-ux9NUpuTA7RnI7y3yIeFmwjVNcagUdBDRPMEzq-ptg_S1WVLeEA9wa-pLwz0mykVLP9uZjvtiRKknFlJqXbdSdHq_pH8ZS-ilWZhUFhwJ8NSvogV3ng35BPomwwliM7g3Y5IEyRX30ZTuaEL6JIPfOapdHOR4lDR-9xeMGdDPOF0ebi3AoyVFPQ-hKLJ0zlk5VQhRMnBT6g-GDe3RE_H3MR7ISk616TJyIgoc_waAA_0-GstMQ9VrjR0YyV-USUawKaDD3qPKvCwDD3fG_CYnGjwfyBlNgwqLSoJG-R-XbCl51iZxDsKbuFpMxTlLlbzCUhaOFlDrV4QS2vk8bMBWMM9PqE-9VZvj0k1xpshNqT-_xAUQBUbXQEMB_262A_siJroB2MjhfdAEKKCpuhtofpFJ6M7dMywFIkezJwjROVMpTfESBY-yEdpab9aGmnrf3zbBXwxbNuA9JfekpXLLKadhO9ItStRoMaEZLcA1gSYrwGQdPuZI1ubnZf7cvd_SWUajXNTwQkRIDt60F-WuTMvFjCJ6uXslODwEPLSXy-Ljp4Qgflmdi59Q84gtFicoVyPYRbUr-gZJtUYpRSDbrg2Pk4OW8m2ViRn_QWxvBnQMxWoRk6brCb_YP843NL5NkDeAaopiwUqwQ_j65rUsG-w3qWEZ0xesDMS-Zvtsf82nHKQxzJHj8TXqUrOogtQQnALfT6TmhKtZvF-xySBtD9AJcOIbvonigqgV3K9CiRfFraJ1Kv3BxZ78Tjia4socb8_Ycqv4KU5RixdAADXrBZoQG4PeXh2nIsgZL1pGA2JfZ7M_GDa9-EWSXno62QVT8DIsiT04a44a5kbRaLASwleHVWBJCO23=w292-h649-s-no
It's a bit pricey. Clean up the copper a bit of lub and push ig on. Then screw back to the post.
Is this a wind up? you’ve repeated what you said.
