- Joined
- 17 Sep 2004
- Messages
- 465
- Reaction score
- 10
- Country
The outside (metal) pipe cracked in the frost. I've cut it off and cut a similar length of plastic pipe (I was told less likely to crack), connected to the original pipe with pushfit.
However, although I was told compression joins would work with plastic, when I connected to the tap with a compression, the pipe just pulls loose. I've used an insert, olive, and tightened with half turn by spanner.
Am I wrong to be using plastic into the tap? Will I have to use 6" metal pipe, then plastic, then back to metal?
