- Joined
- 5 Oct 2020
- Messages
- 140
- Reaction score
- 3
- Country
Hi Guys, I think this will most likely be a bit of a pointless post, however will post anyway just in case I'm missing something!!
I want to install some outside wall lighting, and will be breaking into the existing lighting circuit in the garage, to spur off to a switch and then through the wall to the outside of the house and connect up to the back of the light unit.
However, I want to install around 4 lights outside, along the same front face of the house, but i would prefer to have no wiring showing?
There isn't going to be an easy way of doing this is there? I can't get into the cavity of the walls, as everything is decorated already, and I can't lift the upstairs flooring up as we've had new carpet laid...... Forward planning I know!!
As I said, bit of a pointless post? The wiring will have to run to the other lights on the outside of the house?
