Hi there,
Before we get into the relms of part P I wont be doing any of this work so, it is just to give me an idea of the access I should leave to route cables and if any work is even required.
I am in the process of refitting a kitchen, the original kitchen hobs and socket used a FCU off an existing socket to a double socket behind the oven. Switchable from above the counter.
When the Gas safe engineer comes to fit the gas pipework to the oven and hobs that I have cut (complying with the regulations for ventelation etc) will he be to put a plug onto the hobs and oven and use the existing double socket behind the oven?
If so what is the require rating of the FCU and the plugs. If I remember somewhere that 3A is the normal and recommended by the oven.
Much Appreciated.
Much Appreciated.
