I've stupidly bought an oven without doing enough research, that has a power rating of 4.4kW. Its too high for the current cooker outlet, which is fed from a ring main shared with all the other outlets in the kitchen. The shop won't take it back so now I'm stuck with a 50kg paper weight taking up a large portion of the kitchen floor.
Ok, so the plan is to add a new ring main for just the cooker. Am I correct in thinking it can be wired with a normal loop of 2.5mm twin and earth to the consumer unit? I plan to run the cable myself, which is the most difficult bit, and get an electrician to connect it all up.
