My oven is switched from a double socket in a low level kitchen cabinet. It mostly gets switched off on the oven control panel because it's a pain in the A*** to keep bending down and moving pots etc to get to the socket. I now want to rectify this and have identified the wiring layout to produce a diagram to add a switch at high level. My extractor and under cabinet lights are currently a 5A spur off the ring. I realise I cannot spur a spur etc. So I have attached a drawing of my proposal, Hopefully so that you knowledgeable ones will say that it is the way to do it correctly or offer any advice. My washing mc has the same problem so will this solution be ok for that also. Thanks in advance.
One other thing. Is it allowed to use surface mount plastic back boxed sunk into plasterboard walls?
[/img]
PS The MK single sw sockets i have just bought have 2 earth terminals physically connected. Do I use one for the cpc and one for the fly to back box, or just stick em in the same terminal as usuall.
[/img]
