First post here after months of reading....
I want to tile our kitchen/breakfast room - kitchen floor is screed and the breakfast room is floorboards (quite new as it is an extension). I know I need to ply the breakfast room but I was wondering what the thinnest mm I can get away with so that the kitchen floor isn't too much lower than the breakfast room? The timbers in the breakfast room are quite solid, not any bounce in them that I can see so I was going to see if I could put down 3mm ply (think it is actually 3.7mm) and just use extra adhesive when tiling the kitchen. Does this sound acceptable?
Other issue that I have is that the kitchen floor slopes v slightly downwards away from where it joins the breakfast room - I am not sure how many mm it is but rather than putting self levelling compound down (looks quite tricky) could I just build up the adhesive a bit more? What mm difference would it be ok to do this?
Also regarding the adhesive are there any recommendations of makes to use/avoid
Thanks,
Mark.
Thanks,
Mark.
