i have a combi which has the pressure relief valve output routed outside via copper pipe.
my mother has the normal boiler that heats central heating and hot water tank.there is a copper pipe behind the boiler that is connected into 32mm plastic drain pipe,which goes through the wall and down into a hole that's been drilled into concrete path,and a few stones to top it up,which i assume is a soak away,but it is always seeping water that is overflowing out of the soak away onto her path.
a subcontractor of the firm that fitted it have been out to service the boiler,she mentioned the water seepage to him,his solution is to reroute the pipe round the house the rear drain.which will look crap,
is this pipe not a pressure release system? in which case it should'nt have this water coming out daily,or is this normal,i just need to understand how this systm works before i ring them about their idea of rerouting the pipe.
